if you have it blocked and flat and there is still enough primer on it just take an orbital with a soft pad and 400 and go over it to take the scratches out. if you need to then spray another coat or two of the primer but reduce it 25%. let cure then sand it again. you dont need putty. the primer is enough to fill sanding scratches.
