Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Scratches in the primer filler after blocking
  #36 (permalink)
Old 11-10-2005, 07:46 AM
Scode68's Avatar
Scode68 Scode68 is offline
Ed S.
Originally Posted by Lost in NJ
I also have an older Dupont technical book from a class and they recommend URO at 4:1:3 for a sealer. I put on two coats as a sealer and did a light sanding with 600 wet (hey I have a lot of it). It sands out real nice and no scratches show through.
How old is that Tech sheet? The most resent one shows the sealer being mixed at 3:1:2.
I donít know why there are a lot of people beating me with the guide coat since I said that Iíve been using a light colored lacquer for that. And it also looks to me that I was done with that part as far as using it to block out the high ands low spots. Other than the scratches and the concerns about the URO, I didnít have a problem.
