Scratches in the primer filler after blocking - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 11-09-2005, 06:41 AM
Scode68's Avatar
Ed S.
Here are two quotes from the thread
Originally Posted by Bee4Me
I prefer 600 wet followed by a double stack gray scotch pad dry.
Originally Posted by baddbob
Since then we've had to change to finer grits for prep especially on metalics. My preferred grit is 600 followed by a rubdown with a grey scotchbrite but sometimes I use 800 depending on the mood I guess because I really don't see much of any difference in results. If you're spraying a sealer 400 dry (hand sanding)would be about the coarsest grade I would consider using especially with metalics, 400 wet may be too aggresive IMO, 400 on a DA is usually alright. Bob
Link to Thread
  #32 (permalink)
Old 11-09-2005, 12:13 PM
URO and sanding
I am not pro, but I have been playing.
First of use a guide coat before beating yourself to death chasing problems.
I recently got some hookit II 320 (real cheap) and was using it dry on the URO. That is the ticket. It sands fast and is high enough grit for final sanding on solid colors if you need to do that. The hookit II 320 lasts forever without buildup. I had been using some open cut 320 sheets for my primer.
I also have an older Dupont technical book from a class and they recommend URO at 4:1:3 for a sealer. I put on two coats as a sealer and did a light sanding with 600 wet (hey I have a lot of it). It sands out real nice and no scratches show through.
I also have been using the hookit II finishing film for color sanding and that is wonderful.
  #33 (permalink)
Old 11-09-2005, 08:51 PM
primer
respray 2-3 wet coats/ block with 240 blow off gidecoat sand with 500 da softpad and your ready for paint....
  #34 (permalink)
Old 11-10-2005, 04:04 AM
adtkart@aol.com
I personally don't use anything finer than 320 when sanding dry. The finer grits do clog up more, as there is no way for the dust to escape. If it has to be blocked with finer, use water. It does help with the clogging and also lubricates. Using a brush to clean the paper, in my opinion, reduces the cutting of the paper. You can blow it off with air and get better results. Just make sure that you wear a face mask. You don't want to breathe in all of that dust.
  #35 (permalink)
Old 11-10-2005, 05:29 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
I tried dry sanding 2k primer once with 400 and had scratches
showing up, I never got them when wet sanding with the same paper.
If I dry sand I have to go to 600.
Different papers and primers behave differently, for me 400 is to course
when dry sanding but fine for wet.
  #36 (permalink)
Old 11-10-2005, 06:46 AM
Scode68's Avatar
Ed S.
How old is that Tech sheet? The most resent one shows the sealer being mixed at 3:1:2.
I donít know why there are a lot of people beating me with the guide coat since I said that Iíve been using a light colored lacquer for that. And it also looks to me that I was done with that part as far as using it to block out the high ands low spots. Other than the scratches and the concerns about the URO, I didnít have a problem.
  #37 (permalink)
Old 11-10-2005, 12:48 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
My thinking is this for your problem.
IF it's taking THIS long to sand out something of this size,
Your paper is clogging and your NOT sanding,just rubbing,your "polished" look.
Your spraying the lacquer guide too heavy and clogging your paper with IT.
Fact is, Wet or dry,it should not take this long.
When I do dry sand,I keep my paper blown off with air.
  #38 (permalink)
Old 11-10-2005, 03:14 PM
Scode68's Avatar
Ed S.
The guide coat is applied like a fog, just enough to give it an off color look and when sanded you can see the difference in color. Seems to be a difference between the 1104 applied with the conventional gun and the 1107 applied with a HVLP. I have to add that it seems like I get the polished look after wet sanding with the 400. All of the guide coat disappears though and I canít see or feel any low spots.
While dry sanding I brush the paper off to keep the dust down (or blown when sanding outside) but would often replace the paper when a difference is felt between it and a new piece.
Iíve been pretty busy at work lately so Iím beet when I get home. Needless to say nothing has continued but then again the weekend is almost here.
  #39 (permalink)
Old 11-20-2005, 09:05 PM
New Member
I 've always started blocking with 180 wet, reprime, block with 220 wet, and then DA with 320 and then 400 dry.
It seems to me blocking with anything finer, you'll just be chasing the waves instead of making them straight. It doesn't take long with 180 to block it straight.
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 03:07 AM
"Basic of Basics" How do you properly apply filler? Centerline Body - Exterior 2 02-10-2006 12:22 AM
sandpaper... 38 special Body - Exterior 14 10-11-2005 04:30 PM
primer or filler first? DusterNut Body - Exterior 6 09-25-2005 09:53 PM
brand of body filler, primer, paint to use? montea Body - Exterior 10 03-26-2005 11:01 PM
