Screen Vaporizer for a 4bbl?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2006, 03:42 AM
Ortie666's Avatar
I smell Clutch!
Hey I was wondering if there is such a thing as a electric vaporizer screen that u can put under a 4bbl carb for the winter time. Unfortunatly my engine has a very tough time firing when its cold out.. part of the problem is the intake manafold design, the carb sits over the #3-4 cyl..(BTW its a V6 with custom intake) So all it does it dumps the fuel into those cyl and fouls them, and then the others lean out.. I beleve that a vaporizer screen like the ones found on 4cyl chevettes would help my problem by heating the mixture.. This works very well on the 4cyl chevettes, good enough that u can start one at -35 w/o a choke
Ortie 666
Old 10-17-2006, 06:08 AM
nitro_baller4692's Avatar
floppers forever
so buy a shuvete!probleme solved
Old 10-17-2006, 07:36 AM
poncho62's Avatar
Wiki Edits: 5
There may of been something of that sort made, but if from GM, it would be for a Quadrajet. What carb are you using?
If you took a Chevette one apart, you might be able to make something.................That would be real hotrodding.............
Old 10-17-2006, 08:22 AM
Known traffic menace
I would be looking for a different intake design if I had problems like that. Seems like that wouldn't be good in warm weather either. Just my opinion though. Perry.
Old 10-17-2006, 10:01 AM
gm used those on some of the 2.8 s-10's i believe.....kinda hard to find anymore, and a bit pricey if IIRC
Old 10-17-2006, 01:32 PM
DoubleVision's Avatar
I`ve seen on varajet carbs (primary half of a Q-jet) have heaters under the carb. You could likely use one of these to fabricate to fit inside the air cleaner. This would also eliminate throttle blade icing.
Old 10-17-2006, 02:23 PM
poncho62's Avatar
Wiki Edits: 5
I thought that they were called .."Dualjet".........Quadrajet with the secondaries sealed off
Old 10-17-2006, 02:43 PM
Ortie666's Avatar
I smell Clutch!
It was "Durajet" btw, and I already have a chevette, I have 3 but they fit V6's (look in my photo album). I thouhgt up a new design that I may try, but the heater grill would kick *** because there is a 390cfm holley tunnelram carb on it, And it cant even fit a choke into it unless I did some drilling to the choke horn.. and as for the idea of taking a heater grill of somthing else and making it fit I have thought about it but i wanted to juss make sure there wasnt an easyer way first..
Ortie 666
Type FA transmission fluid 406chevelle Transmission - Rearend 6 03-15-2005 09:03 PM
Oil Pan/ Windage Screen Problems DTL504 Engine 4 05-13-2004 05:37 PM
gas tank suction screen superford61 Hotrodding Basics 5 10-01-2003 09:34 PM
Wide screen troy-curt Hotrodders' Lounge 3 06-14-2003 08:02 AM
4bbl v 2bbl deleteall Engine 4 07-07-2002 08:12 AM
