screening for a screen side pick up - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-29-2005, 07:39 PM
antiquecar's Avatar
old car nut
I know i post some wierd request but I am working on a 1923 Dodge Screen Side pickup and need to find screening. The material was used on elevetor doors, security doors, ect and looks like expanded metal. No one seems to make it anymore. Anybody have any ideas. I will post pictures when my camera returns from a daughter borrowing it.
Thanks
Jan
Old 09-08-2005, 08:03 AM
willys36@aol.com's Avatar
Wiki Edits: 21
My first response to a question like this is to send them to Hemmings Motor News. That book has every obscure parts supplier there is. My experience is that if you can't find it there, it probably isn't made.
I don't have this book but you may find a lead in it.
Old 09-08-2005, 08:31 AM
antiquecar's Avatar
old car nut
Thanks for the suggestions but I have been down those roads. Hemmings just isn't what it used to be. I have a Hemmings Motor News in my office from March 15, 1960 and it has the screenside screens which I need but I have not seen them in years in Hemmings. Most of the screens were converted into grills made our of 55 gal drums. I picked up one side in Chichashee last year and it was used on a grill. The grease actually preserved it quite well.
Nice Willys. I used to run one with a Ford Flat head with Ardun heads and then a 331 Desoto Hemi. I noticed you have one in you photos. Do you still have it? My brother currently has it in a 1933 Ply. coupe which was built in the 60's.
The Dodge truck book you mention is an excellent reference book.
Thanks for your ideas
Jan
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
How did you pick your screen name? Adrenaline_Fiend Hotrodders' Lounge 121 04-02-2005 06:59 AM
heat from one side.... lou707 Engine 1 09-05-2004 05:31 PM
Fan hit upper rad. hose!! mustangdude947 Engine 14 08-19-2004 03:52 PM
Oil Pan/ Windage Screen Problems DTL504 Engine 4 05-13-2004 04:37 PM
