-   General Rodding Tech (http://www.hotrodders.com/forum/general-rodding-tech/)
-   -   Screw mounted slicks repair? (http://www.hotrodders.com/forum/screw-mounted-slicks-repair-214051.html)
Hawkfan 02-05-2012 05:51 PM
I have a set of Hooser 28" slicks that have developed slow air leaks at 2 of the mounting screws. Does anyone know of a repair that would work or would I have to install a tube to stop the leaks?
Any input would be appreciated.
S10 Racer 02-05-2012 06:23 PM
Maybe the screws are too long. The tire bead is the thickest and strongest area of the tire. You could use slime but a tube would probably be the best fix but either way, check the screw lengths.
Hawkfan 02-05-2012 06:48 PM
Thanks
Thanks S 10 Racer. Of all the screws I installed, inside and out, these are the only screws that penitrated. I'll pull the screws and measure.
Thanks again,
1971BB427 02-05-2012 08:26 PM
If they penetrated the bead they're too long. Nothing to do now but install shorter screws and tubes.
matts37chev 02-05-2012 08:51 PM
you might be able to drizzle some bead sealer or repair glue (cold vulcanizing fluid) into the screw holes
worth a try, if you dont want the tubes
Hawkfan 02-05-2012 09:08 PM
Thanks
thanks for the replies.
Hotrod 80 02-12-2012 10:07 PM
Now that the tires have drill holes in them pull the screws one at a time and take the tips off . The tips of the screws are just long enough to cut through ( Moroso). Mark the leakers and as stated add some glue or gasket material . Make sure the slick is got air pressure in it so the bead is tight against the rim . Slicks without tubes tend to leakdown over time anyway . If tubes are chosen they need to be Good ones . Natural rubber and made for racing . They are heavier material to keep from rupturing and wading up around the stem and throwing the tire off balance at speed .
