Screw mounted slicks repair? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2012, 04:51 PM
I have a set of Hooser 28" slicks that have developed slow air leaks at 2 of the mounting screws. Does anyone know of a repair that would work or would I have to install a tube to stop the leaks?
Any input would be appreciated.
Old 02-05-2012, 05:23 PM
S10 Racer's Avatar
http://www.warsprints.com
Maybe the screws are too long. The tire bead is the thickest and strongest area of the tire. You could use slime but a tube would probably be the best fix but either way, check the screw lengths.
Old 02-05-2012, 05:48 PM
Thanks
Thanks S 10 Racer. Of all the screws I installed, inside and out, these are the only screws that penitrated. I'll pull the screws and measure.
Thanks again,
Old 02-05-2012, 07:26 PM
1971BB427's Avatar
If they penetrated the bead they're too long. Nothing to do now but install shorter screws and tubes.
Old 02-05-2012, 07:51 PM
matts37chev's Avatar
I don't understand?
Last journal entry: this is only a test
you might be able to drizzle some bead sealer or repair glue (cold vulcanizing fluid) into the screw holes
worth a try, if you dont want the tubes
Old 02-05-2012, 08:08 PM
Thanks
thanks for the replies.
Old 02-12-2012, 09:07 PM
Hotrod 80's Avatar
Now that the tires have drill holes in them pull the screws one at a time and take the tips off . The tips of the screws are just long enough to cut through ( Moroso). Mark the leakers and as stated add some glue or gasket material . Make sure the slick is got air pressure in it so the bead is tight against the rim . Slicks without tubes tend to leakdown over time anyway . If tubes are chosen they need to be Good ones . Natural rubber and made for racing . They are heavier material to keep from rupturing and wading up around the stem and throwing the tire off balance at speed .
How/where to get slicks balanced? against all odds Hotrodding Basics 7 11-06-2011 04:28 PM
What size slicks to run? onefastchevy Hotrodding Basics 19 08-10-2009 06:53 PM
Slicks!!!! cojohnso General Rodding Tech 11 07-10-2005 12:01 AM
slicks defilade Body - Exterior 2 08-14-2004 05:04 PM
T-56 and slicks? 352FORD Transmission - Rearend 3 08-10-2003 01:03 PM
