Screw in or press in ball joints better? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-09-2014, 04:40 PM
Mutt's37Buick's Avatar
Hoping someone with AFCO parts experience can help me out.
I may be buying some sleeves from Speedway to adapt different ball joints to my lower arms.
There are screw-in and press in-style sleeves.
Ball joint taper and diameters are my main consideations, but is screw-in or press-in a better way to go, and why?
Thanks
Old 05-09-2014, 05:37 PM
life is a temporary assignment
I had screw in on my willys front end... From Art Morrison a-arms...I liked them.. Easy to change if you had to...I really don't think one is better then the other..
Old 05-09-2014, 07:03 PM
I used afco on the front of my home made front suspension on my cougar . the screw in type sleeves worked great, however the lower ball joints didn't fit the threads tight and I could turn the ball joint in the socket with my hand. replaced them with moog and they fit perfectly.
Old 05-09-2014, 08:57 PM
On the street or strip there's not much difference. Are you willing to buy a ball joint socket you might only use once in your life. Circle track that's a different story. You might be changing a ball joint every week. You will want to buy the tool and use screw in ball joints.
Old 05-10-2014, 10:23 AM
Thanks all for your feedback. I'll check into borrowing a socket. Dont have a press at home so both types have that disadvantage. Have'nt changed a bj yet so repair not an issue.
Mutt
Old 05-17-2014, 11:36 AM
Cars, Trucks, Boats
. Most auto parts stores let you borrow a ball joint tool (and other tools/pullers) for free just by leaving a deposit for it... makes a job easy and quick that is nearly impossible without it...
The Following User Says Thank You to BuzzLOL For This Useful Post:
Mutt's37Buick (05-18-2014)
were can i get ball joints rtyauch301 Suspension - Brakes - Steering 6 09-02-2009 01:30 PM
Ball joints... Rickrak77 Suspension - Brakes - Steering 5 10-26-2006 12:05 AM
ball joints knuckles Suspension - Brakes - Steering 4 01-09-2005 09:41 PM
ball joints knuckles Introduce Yourself 2 12-28-2004 08:06 PM
Ball joints - all at once? Stinkin_V8 Suspension - Brakes - Steering 9 05-30-2003 10:02 AM
