Screw in Studs / Guideplate Preference - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2009, 08:05 PM
31fordcoupe's Avatar
Last journal entry: Gunked up 454 water jacket
Any of you have any preference on any particular brand of guide plates and screw in studs? Not certain if there are any particular brands to stay away from. Thanks.
Old 02-22-2009, 08:11 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
i take it you have a machine shop going to do the work right.if thats the case a good machine shop will be able to help you with that desicision.they should know what you will need.the last set i got came from jegs but i never used them sold them to a friend he has had no problems yet. cole
Old 02-23-2009, 07:06 AM
dawg's Avatar
NAVY VETERAN
crane makes quality guideplates and studs
dont buy no name stuff (this isnt an area of the engine you want to put cheap parts in)
Old 02-23-2009, 08:42 AM
racecar100's Avatar
I use ARP studs and never had any to break. Any guide plates are good. I like the step up guide plates the best.
Old 02-23-2009, 04:50 PM
eloc431962's Avatar
Wiki Edits: 37
these guys are right you dont want to skemp on things like this.good name brand stuff thats the way to go. cole
Old 02-23-2009, 09:30 PM
Ok thanks guys. I've already found some ARP studs and Comp Cams guide plates. Much appreciated.
Screw in studs for Vortec heads camaro freak Engine 2 08-02-2007 10:03 PM
screw in rocker arm studs? BadHabitSS Engine 3 09-16-2006 10:12 PM
do i need screw in studs? Scrumgees Engine 3 05-04-2006 10:21 PM
Screw in studs needed? granprix76 Engine 1 11-05-2004 01:14 PM
screw in studs on heads ? inkfixer73 Engine 2 10-06-2003 11:07 AM
