Scuff pad-gray or red - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2005, 12:06 PM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
I got some of that scuff helper that comes in a tube and goes on
a wet scuff pad. I used it with a gray pad, which I thought was
recommended on this forum, but after scrubbing my bumper real good with
it the bumper still had a little sheen left on it. I tried it with a red and
it scratched it much better, but wasn't as even.
What do you guys on here use? Is the gray enough scratch or should I
keep going till all the sheen is gone like I use too when I used
2000 paper?
Old 05-10-2005, 02:51 PM
The grey pad will provide the best surface for paint with just enough texture, the red pad will work and provide more than enough surface texture but may be too agressive for a metalic color and show sandscratches. If you are applying a sealer or primer then the red will work fine with no problems, if you are shooting a solid color the red pad will work fine, if it's a metalic that will be applied directly to the scuffed surface the red may be too aggresive. JMO's
Old 05-10-2005, 09:59 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
I have not tried that scuff helper compound as of yet. Been thinking about it.
I just use a spray bottle with water and keep the area wet which help's alot with the scotch pads as they don't seem to cut as well/long dry.
Unless I'm doing a final go over pryor to paint or on clear.
Think of it this way.
Red = 180-220
Gray = 400-600
This helps me decide which to use IMO.
Has anyone tried the Gold yet? (Guess thats what color it is,kinda light brown)
I saw some in the paint store the other day and it was F-I-N-E.
Kinda like 1000-1200.
Old 05-10-2005, 11:45 PM
RC custom from hell.
I have used that stuff at a couple of dealers, and was pretty happy with the results. Great for fades on insurance work. You could always do it in 600 wet or dry, with a tablespoon of dish soap in a gallon of water. The old and still good standby :-),,,,RR
Old 05-11-2005, 06:13 AM
jcclark's Avatar
The Penny Pincher
I haven't heard of gold color scuff pads but I do use a white.
It's so fine it doesn't appear to be scuffing, it's great for knocking the dust
off of base coat. If I get a bug or piece of dirt in my base I let it dry
and use the white to scuff it off, it hardly scratches it, then I dust another
coat of base over it. If the gold is super fine it sounds like that white I
use.
2 Exhaust Pipes Glowing Red Hot (Part 3- The Head is Off !) white66coupe Engine 15 11-01-2005 05:08 PM
Red 7mm spark plug wires? 67cuda Hotrodders' Lounge 11 07-21-2004 12:30 PM
Uneve Brake pad wear on 2001 Malibu Malibucdl Suspension - Brakes - Steering 17 04-09-2004 11:13 AM
Viper red vs. PPG bright red differnance? zachscc Body - Exterior 0 11-14-2003 11:54 PM
2 Exhaust Pipes Glowing Red Hot (Part 3 !) white66coupe Engine 12 06-14-2003 09:07 AM
