Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Scuffing well cured epoxy primer.
Old 11-15-2007, 10:10 PM
Rag top bird's Avatar
Rag top bird Rag top bird is offline
Hot rods are still the king
I would wet sand with 400 grit and then recoat with epoxy if you have any filler work then you should use a urethane surface primer over that area
