Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Scuffing well cured epoxy primer.
Old 11-16-2007, 05:25 PM
BarryK's Avatar
BarryK BarryK is offline
A scuff pad to the hidden corners will be just fine.
The sanding only needs to be a fast scuff, not like you would do on a previous paint job where MUST make sure there are no shinny areas.
Could you have just sprayed the epoxy over itself without sanding and it stick.
Test show that works pretty good as epoxy tends to stick pretty good to itself well after open coat time, however there are a lot of other variables that can affect the adhesion so it is best to scuff up and good exercise if nothing else.
