The right kind of foam..we used to get the blue foam board from the lbr yard for that sort of thing..check to see that the resino does not eat the foam..regular styrofoam will melt if you get fiberglass resin on it..
Sam
http://www.uscomposites.com/foam.html Styrofoam based insulation foam is OK with epoxy resins. Polyisocyanurate foam is ok with all resins but very expensive. http://www.fibreglast.com/showproduc...-Foam-156.html Quote:
I can't get to the Wiki article right now, or I'd get you a link..But look on there, because there is an article that shows someone making a radiator shroud using a foam mold...It goes through the step by step process....
Sorry I couldn't help more... scr8pin
http://www.crankshaftcoalition.com/w...***_fan_shroud |
Ed Roth, the master
Roth used to use foam... then plaster mixed with vermiculite to do his body bucks..
| Toolbox shadow foam | lumberjacknooj | Garage - Tools | 22 | 12-04-2012 10:30 PM |
| arm rest foam repair | esahlin | Interior | 3 | 08-07-2008 02:36 PM |
| Foam quality... what the numbers mean? | jhenry | Interior | 6 | 04-18-2008 07:14 PM |
| Should I sand landau foam before gluing? | hemi43 | Interior | 4 | 09-17-2006 01:59 PM |
| Foam foam and more foam | Halloweenking | Interior | 20 | 06-07-2003 04:34 PM |
