Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - sea foam in oil???
Old 01-11-2008, 10:34 PM
Haulin327's Avatar
Haulin327 Haulin327 is offline
Sea Foam Is A Good Top End Cleaner......pour It Down The Intake And It Wikk Help Your Car Smog>>>do Not Pour Any Oil Thinning Additive In Oil Unless You Want To Lose Rod Bearings....
iT WILL PROBABLY MAKE THE CAM GO FLAT FIRST
Don't put seafoam,Berrymans,or any of that kind of stuff in the crankcase at all
UNLESS you are trying to lossen up lifters..., and then DONT rev up over 1500
The cam is first to go.. then rods-
That stuff is great to clean the top end but you are taking life off your lower end by putting it in the oil....
