Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - sea foam in oil???
Old 01-11-2008, 09:57 PM
elcaminodragster's Avatar
elcaminodragster elcaminodragster is offline
70 El Camino aka FRANKENSTEIN
Originally Posted by Haulin327
Sea Foam Is A Good Top End Cleaner......pour It Down The Intake And It Wikk Help Your Car Smog>>>do Not Pour Any Oil Thinning Additive In Oil Unless You Want To Lose Rod Bearings....
iT WILL PROBABLY MAKE THE CAM GO FLAT FIRST
Don't put seafoam,Berrymans,or any of that kind of stuff in the crankcase at all
UNLESS you are trying to lossen up lifters..., and then DONT rev up over 1500
The cam is first to go.. then rods-
That stuff is great to clean the top end but you are taking life off your lower end by putting it in the oil....
thanks thats what i heard just wasnt sure. so im safe with no worries if i just put it in the gas tank and through the carb correct???
i have a new cam so im not trying to loosen anything just trying clean the carbon out.
