To seal or not to seal? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-29-2009, 08:09 AM
71haulnazz's Avatar
I had my chevelle down to bare metal, and filler. I prepped the whole car then used Valspar epoxy primer(gray). Than guide coat, sand, prime again. I am painting the car a metallic silver, maybe a shade or two darker than the epoxy primer. And I am going to do a few shades lighter than the cover color to do the stripes. Should I 100% seal the epoxy primer or is it not a must? I have heard from a fwe people that if the color is lighter than your epoxy primer than seal it, if your gonna go dark do not worry about it. What you guys think?
Old 05-29-2009, 10:58 PM
If you used epoxy I wouldn't worry about it and go a head and squirt it. Just prep it good.
Zoop Seal coating for polished aluminum, RESULTS!!!!!!! fordSR Engine 15 02-05-2010 01:04 PM
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 06:15 AM
Oil leak from balancer seal Oldphart Engine 5 02-02-2009 05:51 PM
Front oil pan seal on Small Block Chevys gearhead77 Engine 19 09-26-2004 09:58 PM
Rear Main Seal 1985fiero Engine 1 04-27-2004 10:31 PM
