Seal up gearcase on 6-71 blower? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-09-2010, 10:01 AM
Arrowhead's Avatar
EFI Rules and Carbs Drool
Last wiki edit: The FREE T Bucket plans
Last journal entry: Sold Everything for a new project
Wiki Edits: 5
I have an original GMC blower that I ran for a while. The issue I have is the gear case is open to the bottom of the blower. That's not a big deal, but if you take the blower off, the gear oil runs out all over the intake. Is there a way of sealing up this internal passage so the blower can be removed without spilling all the gear oil?
I was thinking of simple blockoff JB welded inside.
Old 03-09-2010, 11:08 AM
345 desoto's Avatar
Location: Skaneateles, NY Summer/Port St.Lucie, FL Winter
There shouldn't be ANY opening like that. The only thing I can think of that might be remotely close is that originaly the 6-71's were oiled from the engine oiling system, and you're missing an Allen plug somewhere. Maybe some pictures, or a more detailed explaination of where the oil is coming from would help...
Old 03-09-2010, 07:46 PM
Arrowhead's Avatar
Wiki Edits: 5
Yup, look like drain back holes, there's one on all four corners. Probably could be tapped and plugged like you said. It been a few years since I looked up in there and didn't remember them just being holes.
Old 03-09-2010, 08:18 PM
345 desoto's Avatar
It would be best to tap/allen head plug them, rather than JB Weld them. Pressure builds up in the gear case, and might pop the JB Weld out. It wouldn't go anyplace...until you pulled the blower. Then it would drain all over your intake, etc. You shouldn't need to worry about the ones at the back...there's just greased bearings in the end plate.....
Old 03-09-2010, 09:32 PM
XNTRCI-T's Avatar
AKA Lee in KC
Hey >>>----->, it's me, Lee in KC! In the OEM installations of these blowers, engine oil was fed to the gear boxes and drained back into the crankcase, so that's what you're dealing with. Drill, tap and plug, as has been suggested, is the fix.
EDIT: Ooops, don't know how I missed desoto's post that says the same thing I said!
Old 03-10-2010, 10:33 PM
also get a vent on the top of the front cover or you'll be puking seals
Old 05-15-2010, 08:37 PM
Hey all, I'm having the same problem with My blower. What is the best way to tap these holes, from the bearing plate gear side, or the case, intake side? Thanks.
Old 05-15-2010, 09:37 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Vents on the gearcase? I'm running an 8-71, there is no vent, no blown seals. Is there something about OEM blower over aftermarket we don't know?
Semper Fi
Old 05-16-2010, 06:02 AM
345 desoto's Avatar
I also added a gear case drain...along with a push to vent button...
« Turbo Quad 4 | Gmc? »
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 06:15 AM
Ford 351W Rear Main Seal rcm800 Engine 2 06-13-2007 01:19 AM
HELP front crank seal for a 66 430 Conti adeptus_mechanicus Engine 1 06-02-2007 06:14 AM
rear oil seal help alrobjr Engine 5 01-24-2006 08:12 AM
Blower Resistor ChevelleSS_LS6 Electrical 3 06-18-2004 04:40 PM
