I bought a set from a vendor.. and the lens is glass..
even has the halo ring.. for my c-10 they are really cool lights search the web using the adverb and nown and www and com.. |
The UV (ultraviolet) from the sun kills plastic.
vicrod |
Make sure that the headlight vent and the weep hole at the bottom are kept clean and unrestrictive.
One of the biggest problems with this type of light is the heating and cooling cycles that the headlight goes through. If you could imagine, with the headlights on, the temperature inside the lens rises dramatically and the air inside the lens area is heated. Pressure is disapated through a vent in the housing to avoid builtup pressure. When the lights are turned off, cooling takes place and the temperatures inside the lens will deminish causing an intake of outside air (which could contain water vapor) to be taken inside the lens. In most cases, the water vapor will condense on the lens and and lamp housing with any excess moisture running out the weep hole. The inside of the lens may become discolored and a film of water vapor and dirt may coat the inside of the lens. Clean the inside of the lens with alcohol to remove any stain build up. Remember, allow plenty of time for an alcohol vapor to disapate from the lens, before turning them on, or risk an explosion. This is the primary difference between open headlight lens which require bulbs and sealed headlight lens. Back in the 30's, was when the advancement came, so in essence, we have moved back in time to an inferior lighting system. |
Thank you for responding with the first sensible answer since I posted this. That sounds right and I bet since the bulbs are 100 watt high beams, that heat is the key factor here
| The Following User Says Thank You to ChadGresham For This Useful Post: | ||
alittle1 (10-17-2012) | ||
| High beam low beam relays | kleen56 | Electrical | 16 | 12-29-2010 03:19 PM |
| low beam/high beam | cares | Electrical | 2 | 05-15-2008 07:23 PM |
| Sealed-beam adapter for early Chevy?? | fredf | General Rodding Tech | 2 | 05-20-2007 02:34 PM |
| 36 chevy sealed beam headlights | phlattruck | Electrical | 4 | 02-18-2007 08:00 PM |
| Sealed Beam headlights for 38 Chevy Coupe? | beeb | Body - Exterior | 6 | 05-15-2005 07:06 PM |
