Sealer? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2007, 12:11 PM
Sealer?
well i have been reading like a mad man before i start painting and have a question different then one i could fine. this will be my first paint job so throw any tips my way if you you think need be. i am using martin senour paints from napa. here is my question, i plan on stripping the car bit by bit and doing my filler work, should i immediatley seal that area once done with the body work or go ahead and prime? oh yeah flex additive how much should i use? I'm a newby haha
Old 07-27-2007, 12:34 PM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
Sampson,
I'm certain that some of our Paint Guru's will chime in here, and if you do a Search you should find a bunch of information, but the generally accepted rule around here if you are going to strip the car is to use a Wax and Grease Remover and spray some Epoxy Primer on the car, then apply your Bondo-why? So that if moisture should somehow find it's way behind the Bondo it won't rust-as far as flex additive, there are those here who think it's Snake Oil-
Old 07-27-2007, 01:23 PM
302 Z28's Avatar
There are two schools of thought about this (like you needed something else to consider ). Some advocate priming bare metal first then doing body work on top of the primer. Others say do the body work on bare metal then prime. IMO both work equally well. Old school says body work on bare metal then prime. My thinking is that whatever you do once you strip down to bare metal epoxy prime with SPI self etching epoxy first.
Vince
Old 07-28-2007, 01:47 AM
Countilaw's Avatar
Cox Custom Cars
Save yourself some time and money..... Bare metal, epoxy prime, body work, 2K high fill primer, block sand, sealer, top coats.
Etching primer is a waste of money and time. If the bare metal is sanded, the epoxy has plenty of tooth to adhere.
remember: Etching primer does just that... etch the metal. If the metal is already etched from the sanding, why etch again?
Some people claim that etching primer prevents rust.
What causes rust? Oxygen!!! if you seal the metal under epoxy, Oxygen can't get to it to rust it. So why spend the extra money on another product.
You can spend money on Epoxy Primer which also works as Sealer. Two products in one. That's why it's labeled, Epoxy Primer/Sealer.
So we go to the paint store and we buy:
Etching Primer plus Activator
Epoxy Primer Plus Activator
2K High Fill Primer plus Activator
Sealer plus Activator
Top Coats
Or:
Epoxy Primer/Sealer plus Activator
2k High Fill Primer Plus Activator
Top Coats
So which list do you want to use? The long one or the short one?
Frank
Old 07-28-2007, 10:28 PM
thanks guys i happened to bump into an old friend who is a painter he steared me right on it all alond with your help thanks guys.
Has anyone ever had sealer turn into wrinkle paint before? JoeySummers84 Body - Exterior 5 02-06-2006 07:31 PM
Seam sealer staying tacky :( Ripped Body - Exterior 4 10-16-2005 01:36 AM
White Sealer nova69 Body - Exterior 5 08-26-2005 02:51 PM
New heads...thread sealer or not? wickster Engine 3 03-06-2005 10:29 PM
Gasket sealer atlantis Engine 4 02-27-2005 09:41 PM
