is a sealer coat needed again? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-01-2011, 10:49 PM
Guys,
I got started on my paint job today but had some run problems. It was the first time I used my new Finishline gun and this is the first time I have tried painting a car. I sprayed my SPI epoxy primer all over the car as a sealer and have runs in three or 4 places. The bodywork looks great but the sealer has the runs and some orange peel. Can I just sand the runs out and wet sand the body with 400 or 600 grit then just base coat it without re-sealing it?
Old 05-02-2011, 05:12 AM
deadbodyman's Avatar
Wiki Edits: 11
Absolutly,I always sand my epoxy sealer...You spent all that time getting everything slick why would you start spraying over a textured sealer ???
dirt and runs must be gone BEFORE you start painting.
Dont forget to post bragging pics when your done...
Old 05-02-2011, 05:54 AM
Last journal entry: 50 Ply wagon
You say you put a coat of epoxy primer as a sealer. Primer is just that,a primer. There are separate sealers used before painting and although you can paint directly over a good primer, I would check with the topcoat directions to see if you should put a sealer coat on top of the primer before topcoating with the finish coat.
Also, when you sand out the runs, if you sand through to bare metal they must be primered again .
Old 05-02-2011, 08:29 AM
I will be posting video of both the paint job and the paint booth I built. I have to say I'm pretty impressed with my booth. The paint job my still end up looking like crap but that is one fierce paint booth!
Old 05-02-2011, 06:34 PM
302 Z28's Avatar
SPI epoxy primer is one of the best sealers on the market.
Vince
Old 05-03-2011, 05:00 AM
Wiki Edits: 11
Vince
Its the ONLY sealer I use...
wet sanding before sealer/base coat xpsyclonex2002 Body - Exterior 6 04-27-2011 05:47 AM
Dupont one coat enamel sealer dannyidp Body - Exterior 1 01-22-2010 08:37 AM
Purpose of sealer coat? (Newbie alert) 66 Restomod Body - Exterior 9 09-20-2008 01:23 PM
Should I plan on doing a coat of sealer after body filler and before 2K High build? Ripped Body - Exterior 2 01-14-2007 11:47 PM
Sealer needed or not??? Early B's Body - Exterior 6 01-24-2006 09:15 AM
