sealer or epoxy first which one - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2006, 11:22 AM
rolandag2's Avatar
I have replaced my roof and where the roof meets the drip rail are done and I would like to seal it and put some epoxy on it but which one do i use first. I would like to use some filler to repair the areas that need some minor filling but don't know what process to use first. Any help on this problem would be great thanks.
Old 10-20-2006, 11:32 AM
Most guys recommend putting your epoxy down first and then do your filler work on top of the epoxy while its in its re-coat window, that way you don't need to sand the epoxy before applying filler.
Old 10-20-2006, 01:16 PM
Buick Hybrid Guy.
Yep.... 100% correct for resto's.
Epoxy on bare metal and then sealers/fillers.
Epoxy primer will have 15X's the adheasion than bare metal to fillers and sealers. The protection is nice too
Don't use a sealer when you go to paint. Get your primer all sanded down to 600G and use basecoat directly on the fresh sanded primer. You'll retain more gloss with less die-back.
Hope that helps,
Scott~
Old 10-20-2006, 02:21 PM
Irelands child's Avatar
Here is a good LONG thread
Take a look at this thread - it's long, but epoxy goes down first then filler/2K/Paint.
Filler over epoxy or Epoxy over filler? Here is some good info
Dave
Bare Metal Mollard Body - Exterior 71 09-25-2008 01:48 PM
SPI Epoxy as Sealer nova69 Body - Exterior 2 09-06-2006 02:50 PM
epoxy sealer over these spots? staircasesurfer Body - Exterior 13 03-16-2006 09:44 PM
Is epoxy sealer suppose to be shiny? FrankR Body - Exterior 1 09-25-2005 09:03 AM
What grit? before and after epoxy sealer ? 67LS1T56 Body - Exterior 7 08-17-2005 10:04 PM
