Sealer,Epoxy,or more G2 ?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-13-2005, 10:09 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
Someday, I'll listen to that little voice in the back of my head.
I'm doing a glass jr. dragster body and shooting over the existing bc/cc job.
I shot FeatherFill G2 and blocked out. Had a few small cut thru's and decided to chance it. After shooting the first coat of black I knew I was in trouble.
Dieback. And, A few missed sand scratches.
Would I be better off spotting the areas with sealer,Spot epoxy,or spot some 2G??
Only thing I have is the epoxy,Dupont Full-Poxy, I can pick up whatever is needed and I really don't want to wait on the epoxy for a day cause I'm not taking any more chances.
Would some reduced G2 do the trick? I've never used it this way,as a base coat spot so I'm not sure.
I have to resand the base anyway so sealing and paint is not a priority.
Sad thing is, I KNOW better, but we all have our head up our tail's occasionally. That,and,I should have known better than shoot paint on the 13th.
Old 12-13-2005, 10:27 PM
Mike, I wouldn't spot in the G2, it may work-never tried it, but I've got a feeling it won't work. You might be better off to apply another coat of base, let it set overnight, lightly sand it and shoot one more coat on. I'm picturing the G2 is probably sucking up that basecoat? but i may be wrong. Or you could sand the base off and apply some epoxy and let it set for awhile but that's going to cause a delay in plan. I've shot base over G2 before without any problems but I usually do a 2k urethane or an epoxy primer over the G2 and sand one more time.
After reading your post again it sounds like the only areas you're having trouble with are the cut throughs, sand the basecoat back in these areas and apply a 2k sealer or urethane primer reduced as a sealer, should do the trick I bet.
Old 12-13-2005, 10:39 PM
Bee4Me's Avatar
It's just the cut's Bob. No lifting or such,just an obvious defect in these areas.
I ran out of everything primer in the shop so I have to get some anyway.
I thought about just rebasing but I'm afraid the solvents will just repete the process. Shooting Nason as well so SEVERAL coats will be needed for it to look black anyway.
You think 2K will seal these up OK?
I may try some base first just to SEE tommorow but I'll have something else just in case.
I alway's am a stickler about cut's and getting my primer right before paint so I've never had to deal with this type problem but I really didn't think it would be this bad.
Lesson Learned.
Old 12-13-2005, 11:25 PM
Yeah, you might be able to sand it some and rebase. Kind of like dealing with a lifting problem, if you can eventually get the base on and it looks good and has flashed long enough to apply clear it'll be ok. Were the cut throughs showing gel coat or the old finish?- just curious what is sucking up the solvents so fast. Another thing that happens to me once in a while is with black I tend to put it on a lot wetter than with other colors for some reason, this makes for more solvents laying there that need to come up and out or they go in if the substrate wants to soak it up. I bet it'll be fine the next time around. Bob
Old 12-14-2005, 09:04 AM
Bee4Me's Avatar
A couple are thru the existing clear into the old paint and it's sucking the new base right in and leaving it nice and grainy.I'm really thinking to spot some primer as a few of these areas will have a kandy job over them and IF they come back after that,well, I don't even want to go there.
Some day's our stupidity is only surpassed by our complete lack of intelligence.
Thanks for the advice. I have a bad habit of doubting myself even though I know what to do. Just keep ignoring that voice for some reason.
Old 12-14-2005, 09:30 PM
Bee4Me's Avatar
Guess I must be snake bit as this thing refuses to take paint right.
I scuffed the base and shot Nason activated sealer over the entire body.
This flashed for 1 1/2 hr. at 70-75* and was DRY to the touch.
Tacked off and shot the first coat of base.
Spot WRINKLES!!!
I guess, I laid the sealer a little to heavy,as I would have thought that long a flash "should" have been fine and with just one med coat. It will cure out and some more sanding and I should finally have a base coat on this problem child.
Any thoughts as to why this happened?
This one is obviously going to be a fight to the finish but I don't give up easily so IT best be up for the battle cause I will beat it.
FeatherFill G2 shoddy_f-body Body - Exterior 20 08-10-2005 08:11 AM
trick flow G2 owners engine rebuild help zamaro Engine 1 09-24-2003 08:36 AM
