Sealer on Head Gaskets - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2006, 03:05 PM
I am about to install iron vortec heads on my 350 using Felpro 7733PT2 gaskets.
Do I need to apply sealer to these? The general instructions that were included say to install fiber faced head gaskets dry but how do I know if these are fiber faced?! They're blue, so is the blue material the fiber coating?
Does block deck surface finish dictate the need for sealer regardless of gasket type?
I have Permatex Copper Hi-Temp Sealant in case I do need to use it.
Thanks!
Old 02-05-2006, 03:10 PM
Infomaniac's Avatar
Twin Turbo Drag Boat
Last journal entry: Random In Progress Shots
Blue Fel Pro gaskets go on dry man. Can you see metal underneath? Around the cylinders? if so the blue will melt down under heat and seal off.
which head gaskets 69 Ragtop Engine 4 05-06-2004 07:34 AM
which head gaskets to use montea Engine 3 02-11-2004 07:36 AM
Head Gaskets twoteam Engine 1 03-17-2003 11:50 PM
SBC Head gaskets.....which ones? TheZaZ Engine 6 03-15-2003 10:36 AM
Head gaskets onehotchev Engine 1 03-08-2003 04:09 PM
