Sealer on intake gaskets ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-15-2007, 08:56 PM
junkyardjeff's Avatar
I am putting on a used aluminum intake on a 302 Ford and should I use a sealer around the ports,its been a long time since I have messed with aluminum intakes and I want it to seal good. Jeff
Old 05-15-2007, 09:40 PM
If you use something like a FelPro pinto seal gasket, no, you don't need sealer around the ports.
Old 05-15-2007, 10:28 PM
Classix_Lover's Avatar
Music soothes the soul
Last journal entry: Wiring finished finally
You can use sealer to hold the gaskets on before you drop the intake on. I did that with some silicone and it worked just fine.
Old 05-15-2007, 11:28 PM
That is true, what works even better and faster is weatherstrip adhesive.
Good old Chevy intake gaskets shoes Engine 3 03-25-2007 07:33 PM
Seam sealer staying tacky :( Ripped Body - Exterior 4 10-16-2005 12:36 AM
Intake manifold gaskets for alum. heads and intake mustang66maniac Engine 6 02-20-2004 11:19 AM
chevy 4.3 intake gaskets Bugsy Engine 3 12-12-2003 06:51 PM
port matching the intake. Jmark Engine 9 12-08-2003 10:13 AM
