Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Sealer with to much dry spray
Old 05-10-2012, 09:31 AM
Imagery Imagery is offline
Thank you for your help and suggestions. I spent the day yesterday changing up the paint booth air system after realizing I had a positive air flow (plastic walls pushing out) because of inadequate intake air supply. Now the walls suck inward and the air flow moves from front intake side to exhaust, I also added a third fan to help increase suction. I sanded everything back down to sealer transparency to the surfacer beneath. It further exposed some minor imperfections as the sealer acted as a filler as well. Now I will try it again with slower reducer with about 5% more reduction, adjust gun fan pattern better, work from intake side of booth toward exhaust side. I'll do one medium wet coat and make sure it covers well then I can start base coat and clear. I'll follow up with my results when I finish.
