Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Sealer over 2K primer surfacer, yes or no?
Old 11-17-2005, 06:40 AM
Scode68's Avatar
Scode68 Scode68 is offline
Ed S.
Since the primer-filler Iím using can be used for fill and the mix ratio changed for use as a sealer I get your point. I tend to think that the filler is so you can sand out the imperfection and then the sealer is used to give you a uniform color to base over. I also suspect that since they give you a window where the sealer should be based over that it also acts lick an adhesion promoter. When that window is gone you will have to sand it anyway in order to get the base to adhere properly.
