Sealer over unsanded 2k - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-12-2012, 11:18 AM
Mach1460's Avatar
Last journal entry: Project 92' Eddie
Just curious, can I spray epoxy reduced 50% (sealer) over unsanded 2k primer or does it have to be blocked??
I have a few spots on my vehicle that didnt recieve any body work and were just stripped and epoxied and when the 2k primer was sprayed on they looked very smooth and glossy, Im wondering if I can save a step by not blocking these areas?
Old 09-12-2012, 11:37 AM
swvalcon's Avatar
Last journal entry: rust on lt body shell
NO!!!!! any 2-k filler primer most be sanded. The only ones that dont are those that you can over reduce and also use as a wet on wet sealer but you have a very short recoat window. On average 20-30 mins. Take the time and sand it.
Old 09-12-2012, 01:04 PM
Mach1460's Avatar
Thanks for the heads up, I didnt think so but you never know
Old 09-12-2012, 01:10 PM
Mach1460's Avatar
Wait, does it litteraly have to be sanded or can I hit it with a red or grey scuff pad??
Old 09-12-2012, 01:23 PM
put up or shut up
if you sand it you're getting better adhesion and straighter results.
The Following User Says Thank You to tech69 For This Useful Post:
cyclopsblown34 (09-12-2012)
Old 09-12-2012, 02:21 PM
Mach1460's Avatar
thanks guys, i went ahead and wet sanded with 320
Old 09-12-2012, 05:33 PM
mitmaks's Avatar
Last journal entry: Grille
It's all in the prep, do you want it to look nicer-go ahead and sand it.
Of course it will help with adhesion of whatever you put on top of it as well.
sealer swvalcon Body - Exterior 1 08-19-2011 04:06 PM
Help with sealer jesuscowboy Body - Exterior 1 04-10-2009 04:35 PM
do I need sealer??? daoldbuick Body - Exterior 3 10-19-2007 08:25 AM
Sealer? Sampson4721 Body - Exterior 4 07-28-2007 09:28 PM
Epoxy sealer/seam sealer/paint equip Blackdog Body - Exterior 17 10-21-2004 11:19 PM
