sealer peeling - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-27-2012, 12:42 AM
sealer peeling
hello
im working on a old cutlass
the car had an old singlestage paint ( very old )
i sanded the paint , not alway trough just enough to make a good grip
primed , sand everything flat
as usual some little spot bare metal and some old paint spot apparer
degrease tag rak clean everything get ready to seal
now the problem
when the sealer meet the old paint , it's peeling..... right away !!!!!
i used a spi sealer
any idee or suggestion
thanks a lot
Old 09-27-2012, 05:51 AM
novafreek6872's Avatar
Nova Guru
"as usual some little spot bare metal and some old paint spot apparer"
Why didnt you go back and spot prime these areas?
Peeling sealer sounds like the car wasnt sanded well enough or the surface is contaminated.
Hopefully experts will weigh in.
Andy
Old 09-27-2012, 06:22 AM
swvalcon's Avatar
Last journal entry: rust on lt body shell
Is the sealer peeling or is it lifting the old paint causeing it to peel?
Old 09-27-2012, 10:13 AM
yes it's lifting the old paint ....making it to peeling
Old 09-27-2012, 10:26 AM
put up or shut up
strip it or use waterborne primer as a barrier coat. Obviously stripping it is the better choice.
Old 09-27-2012, 10:34 AM
What is happening is the solvents from the sealer are getting under or into the substrate. That substrate being your old paint (very old). It was probably not prepped well when that paint was applied. The substrate under it was likely not sanded well. When this happens and you apply new primer, paint, sealer over it the wet primer, paint, sealer's solvents get UNDER the paint lifting it up off the poorly sanded previous substrate.
As Henry said it really should be stripped. If you wanted to "save" it, you could feather it out with finer paper and apply a product without so much solvents in it like a surfacing primer. Apply it drier so that the solvents don't soak into or under the substrate. You apply a few coats of primer letting it dry a good long time between coats and you create a "barrier".
But honestly, you are playing games doing this as it really should be stripped.
Old 09-28-2012, 12:36 AM
what kind of primer surfaces ?
when i googled i find only hight builder or sealer.....
Old 09-28-2012, 10:01 AM
put up or shut up
a surfacer is another name for high build, if I'm correct. Urethane, Polyurethane, and now some make epoxy highbuild. Really want to try epoxy highbuild and can imagine it's tough as nails.
how to stop peeling clear cutthroatkid Body - Exterior 6 01-29-2012 03:19 PM
peeling....paint? BMM Body - Exterior 5 02-15-2007 04:22 AM
Epoxy sealer/seam sealer/paint equip Blackdog Body - Exterior 17 10-21-2004 11:19 PM
peeling chrome rajin-cajin General Rodding Tech 7 01-08-2004 07:08 PM
Peeling paint and paintjob 78 monte Body - Exterior 4 10-21-2002 04:51 PM
