sealer question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-23-2009, 02:36 PM
sealer question
is sealer just thinned down primer ?
doing a black paint job and want it like glass with no scratches under the paint etc
never used a sealer before so would like to give it a try
can i just over reduce my 2k epoxy?
thanks
tommy
Old 06-23-2009, 03:22 PM
Epoxy is an ideal sealer. Check the sheets, but over reducing (to a point) should be OK.
Heed the recoat window; epoxy is slow.
Old 06-23-2009, 03:28 PM
thanks for the reply
its sickens epoxy but dosnt say that it is a sealer
should this be ok?
thnaks again
tommy
Old 06-23-2009, 04:07 PM
should this be ok?
thnaks again
tommy
You can spray it as a sealer without over reducing it, no problem. Just spray it slick and heed the recoat window and you'll be fine.
383 stroker 73monte Engine 13 05-11-2016 11:17 AM
supercharger.... 73monte Engine 16 07-24-2010 10:27 AM
Sealer Question STATUTORY GRAPE Body - Exterior 5 01-31-2008 07:58 AM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 01:20 PM
Hi All I just Joined, Questions Re:454 rebuild Gay-Shark Engine 8 11-29-2003 10:25 AM
