Sealer Tint Recommendations - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-06-2011, 03:04 PM
Hello everyone, I've posted a few times here but this is the first thread I've started.
I tried to search as best as I could before asking so please excuse any oversights.
I am paining a Mustang convertible back to red, however, it won't be the factory red. I plan on using HOK Meteor Maroon (a metallic color), which is a very close match to factory but a bit more custom.
I'm looking for suggestions on tinting the sealer for better coverage and to help hide the eventual chips.
Here is a sample of the Ko-Seal II tintable sealers on the TCP Global site using KS12 - silver sealer tinted with KK11 apple red, I will be going with something a bit darker for the tint like Burgundy.
Since I'm painting with a metallic color, I'm wondering what your opinions of the effects of having a "silver" tinted sealer would be (like this example shows)?
If it were you, would you stick with the white sealer and tint of my choice?
I will be using HOK Kandy Koncentrate paint for the tinting, as they recommend, however, I'm not sure if these paints are high concentrated specifically for tinting or if it's just a paint that can be used to tint.
Thanks in advance, any suggestions are greatly appreciated!
Old 02-06-2011, 07:15 PM
sealer colors
white sealers will make the brighter colors pop even more, darker sealers will tone them down a bit. I would go to your nearest paint supply house pick up some white and then grey sealer. to a test peace with the color you choose as a topcoat and go from there.
Old 02-06-2011, 07:44 PM
Countilaw's Avatar
Cox Custom Cars
Actually, under RED, you want to use a YELLOW base. If you are using a true candy color, go with the silver base.
Some people tend to say Kandy thinking it's going to be a true Candy color. Which it's not.
True Candy colors use a base of gold or silver and the candy clear is applied over it. This is what gives the paint a candied apply appearance.
Old 02-07-2011, 10:22 PM
Rag top bird's Avatar
Hot rods are still the king
I would use a medium gray that is what Dupont used on the E9 color on the mid 90s mustang
What is Tint ? Bilster Body - Exterior 5 10-05-2008 08:29 AM
What tint to use in Bondo Jmark Body - Exterior 5 05-16-2008 11:01 AM
Epoxy sealer/seam sealer/paint equip Blackdog Body - Exterior 17 10-21-2004 11:19 PM
window tint 61wagonair General Rodding Tech 7 07-16-2003 08:23 PM
