Sealing Around Lap Welds - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-20-2007, 02:10 PM
I'm patching in new pieces of sheet-metal to replace the rusted out portions. I'm butt-welding as often as possible, but there are some areas where I simply have to lap-weld a patch in.
For the lap-welded patches, I need to seal around the edges of the unwelded sides to prevent moisture from getting in. What are good products that can be used as either a brush-on or squeeze-in sealant?
Old 08-20-2007, 08:30 PM
I've used Eastwoods Seam Sealer, the brush on type and have had good luck with it.
Paul
Old 08-20-2007, 09:28 PM
If this is in a boxed area that can't be cleaned for primer application then you're best off coating with a cavity wax type spray-3M's rustfighter, Amsoil HD-MP, or Transtar Amber Coating, Cosmoline...
If you have access to the backside for cleanup you can coat the area with epoxy primer then seamseal with a quality sealer like 3M Ultrapro URETHANE seamsealer, or Fusor or Transtar equivalent. Heck, even roofing tar has also been used for years-anything that will protect the metal and not dry up and crack later to hold moisture.
Stay away from the older solvent based seamsealers-they shrink, harden and crack with age and have caused the death of quite a few cars over the years.
Old 08-21-2007, 05:59 AM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
Asphalt based roofing tar can be thinned with mineral spirits so it flows better into the joints. After that sets up a bit, then coat it with un-thinned tar.
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 09:45 AM
"Basics of Basics" Sectioning a Body MARTINSR Body - Exterior 7 11-24-2008 12:04 PM
Question on grinding, filling, blending and seam sealing welds Ripped Body - Exterior 10 09-19-2005 09:30 AM
Any One Lap or OTC veterans? hotroddesigner Hotrodders' Lounge 0 08-29-2003 12:48 AM
Goop sealing interior welds? 327ImpalaSS Interior 3 02-15-2003 05:31 AM
