sealing "flare" type exhaust flanges
I have an annoying exhaust leak at the flange between the manifold and exhaust pipe. This is a stock 351 Ford flare type joint (the manifold side is tapered and the pipe side is flared to fit against the taper) with no gasket. What's the best way to seal it up? (I can't believe "search" did not turn up some good answers to this...but I couldn't find any.)
Dewey
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod. |
I have had good luck by coating the taper and the flange with grease, (the grease lets the pipe slide into place without binding). button everything up and all should be good. If not I do as posted above, just using a pry bar and a BFH. 1 of the 2 should get the job done as long as the pipes and manifolds are in good shape.
Steve |
I have smeared the taper and the flange with the "ultra copper" high temp silicone, and sealed up leaks like yours..... it's only temporary, but lasts about a year if you let it set before you start up.
| Exhaust location advice needed. Pic enclosed | hemi43 | Engine | 3 | 06-29-2005 04:06 PM |
| yes, another exhaust thread | Chadman | Engine | 9 | 01-05-2004 07:20 PM |
| small exhaust diameter up front and big out back?? | smlblcks10 | Engine | 76 | 01-01-2004 11:24 AM |
| What type of exhaust system???? | buzz_buzzer_ | Engine | 2 | 11-26-2003 01:51 PM |
| Cam Help | black66 | Engine | 3 | 05-12-2003 06:15 PM |
