Sealing metal tear without welding - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-12-2011, 09:07 PM
67Elcamino's Avatar
What is the best way to seal a small 1/2 inch tear without welding. Can i use something like JB Weld or just poly filler?[IMG][/IMG][IMG]
Old 09-12-2011, 10:14 PM
35terraplane's Avatar
tear
It looks like it is right on a weld, it also looks like you are going to have to pound on that area. If it were me I would weld it back up poly filler will fall out in a short time, I would think and I don't know what JB weld will do.
Bob
Old 09-13-2011, 02:05 PM
If you absolutely cannot weld it, do the hammer and dolly
work and then use panel adhesive to fill the gap.
You can then use AllMetal or body filler to smooth it all out.
Old 09-13-2011, 06:29 PM
take 3 minutes to weld that shut and be done with it. Glues and puttys are just band aids IMHO.
T-350 trans, Teflon or metal sealing rings? bodie filyaw Transmission - Rearend 1 02-06-2011 08:09 PM
metal tear repair Hwyhogg Body - Exterior 4 01-22-2010 05:07 AM
Welding pot metal oldguy829 Body - Exterior 3 09-02-2008 03:56 PM
problem TIG welding new metal to old metal 53LEDSLED Body - Exterior 5 09-10-2006 01:38 PM
welding a metal cowl hood scoop to a metal hood? project66 Body - Exterior 7 11-10-2004 10:25 AM
