Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Sealing a new gas tank or not?
Old 05-07-2011, 12:55 AM
milo's Avatar
milo milo is offline
point on positive
I too have had a "treated"..."coated" fuel tank failure and it wasn't simply a leak.
What happened was a bit of the coating got free and found it's way downstream ending up in the carb causing the engine to run lean and burned up a valve .. Ended up with buying a valve job $$$ plus a new tank $$$..
