Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Sealing a poly tank?
Old 10-07-2012, 09:56 AM
boatbob2 boatbob2 is offline
boatbob2
Removing fittings...
Hi,remove the fittings,then using 40 grit sandpaper,rough up that area,very good,(about a 3 inch square) then using EPOXY and 10 ounce cloth,put about 3 to 4 layers of cloth on,( I would use 10 ounce boat cloth)(fiberglass cloth) where the holes are ,in the 3 inch square,,then using a spatula (metal or plastic,) remove excess epoxy from cloth. leave it for 24 hours,in a warm place,you will be good to go.
