Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Sealing a poly tank?
Old 10-07-2012, 01:16 PM
ForceFed86 ForceFed86 is offline
Originally Posted by boatbob2 View Post
Hi,remove the fittings,then using 40 grit sandpaper,rough up that area,very good,(about a 3 inch square) then using EPOXY and 10 ounce cloth,put about 3 to 4 layers of cloth on,( I would use 10 ounce boat cloth)(fiberglass cloth) where the holes are ,in the 3 inch square,,then using a spatula (metal or plastic,) remove excess epoxy from cloth. leave it for 24 hours,in a warm place,you will be good to go.
Do you know if most epoxy/resins are compatible with ethanol? Any specific ones that you know 100% are? I've had problems in the past with certain epoxies etc....
thanks!
