sealing primer or not to seal - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-18-2012, 07:12 PM
hi i am using an acrylic lacquer primer and my question is after applying a layer of body filler and priming do i need to seal the primer or can i apply the paint over the primer with out sealing it ? i have read that the filler would absorb the primer/ paint and show through the paint
Old 01-19-2012, 06:09 AM
deadbodyman's Avatar
Wiki Edits: 11
Did you also read that lacquer primer is the absolute worst kind of primer to use??? Do yourself a favor and toss that stuff ,even the cheapest brand of 2K primer will give you a better result...
Old 01-19-2012, 10:02 AM
I seal everything using PPG sealer but that is using urethane primer. I haven't used lacquer primer in a long time. Big reason i seal though is because i believe it helps the paint stick a lot. If you ever get sealer overspray it seems a lot harder to get off than primer overspray where i believe in its stick, and basecoat goes on wet on wet, or real close to that into the sealer. Its also an easier application straight on top of e-coat for new panels rather than having to shoot primer then waiting for that to dry to apply the base.
Old 01-20-2012, 06:23 PM
thanks for the great info
Should I primer or clear to seal a repair? bumblebee1956 Body - Exterior 4 12-30-2010 06:05 AM
Anyone use Omni 2k Urethane primer, do I need to seal this for BC/CC???? JD's camaro Body - Exterior 6 01-25-2009 08:29 PM
sealing primer 37 plymouth coupe Body - Exterior 12 07-01-2008 09:20 PM
Sealing Primer oldschoolrods Body - Exterior 6 10-13-2004 11:08 AM
Primer sealing questions ChrisMiddleron Body - Exterior 3 12-22-2003 01:47 PM
