sealing rings - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2009, 05:42 PM
sealing rings
I just got my kit for my th350 and the sealing rings are different from what I had before, they are orange and don't interlock like the other ones. they seem to hard to be teflon but they could be. where the two ends meet they just have opposite tapers that overlap. are these decent enough for a stock to mildly modded rebuild.
Old 02-08-2009, 07:14 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I've used that design for years on the t-350 trannys.
Old 02-08-2009, 07:39 PM
good to know, thank you. they are a bit thinner also is this ok. just lube the heck out of them and all should be well?
piston rings please help 67RS-Groundpounder- Engine 6 02-08-2009 08:15 PM
Honing and rings question imacarfan2 Engine 13 07-04-2008 07:53 AM
Gapless Piston Rings - Do I Need Them? leejoy Engine 13 12-31-2007 06:37 AM
Need More Info On Piston Rings Canadian Charlie Engine 1 02-25-2006 05:00 PM
piston rings crshrmn3 Engine 3 09-27-2002 11:06 AM
