sealing a sunroof - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-11-2005, 02:08 PM
zipfactor's Avatar
Last journal entry: Just starting
sealing a sunroof
Hey all,
I have a '76 trans am, and the guys that owned it before me chopped up the roof skin and put in a sunroof. The sunroof is in pretty decent shape, but they never sealed it to the roof skin, they more or less put it in and didnt finish the job. I was wondering if sunroofs just got sealed to the top of the roof with some kind of sealant. Also, is that all that really holds the sunroof to the roof skin. Thanks all
Old 08-11-2005, 02:17 PM
poncho62's Avatar
Wiki Edits: 5
It needs some sort of sealant and there are little clamps that are tightened from the inside. If you take off the inside trim, you should see them.
I would suggest removing the whole unit to seal it properly.....
If you areen't sure what sealant, see a auto glass shop. They will have what you need.
Old 08-11-2005, 02:35 PM
zipfactor's Avatar
do you know where i can get these "little clamps" from?
Old 08-11-2005, 03:31 PM
35chev/302gmc's Avatar
drain tubes
make sure that the there is a drain tube in each corner and that they do drain.
1935 chevy,masters
Old 08-11-2005, 07:27 PM
zipfactor's Avatar
there are drain tubes? where are these at on the sunroof? where do they drain to? My car has the type of suroof that overlaps on top of the roof skin.....I'm not sure if it has drain tubes......or if it has little clamps. Does anyone know where i can get these little clamps?
thanks all
Old 08-11-2005, 09:47 PM
Your style sunroof might not have clamps. Usually these are held in place by the interior piece with screws located around the perimeter, usually the screws are hidden by a piece of trim which must be removed. Take the screws out and the sunroof assembly should lift out. You'll see a foam gasket that is probably deteriorated and now leaking, replace the gasket with some universal weatherstrip material or lay down a nice bead of clear silicone sealer and reinstall the sunroof, wipe off the excess sealer with wax and grease remover. These universal fit older style sunroofs don't have any drains. Good luck, Bob
Sealing Primer oldschoolrods Body - Exterior 6 10-13-2004 12:08 PM
sealing qjet lead plugs Jmark Engine 3 11-05-2003 12:21 AM
Fuel Tank Sealing JimmyL Engine 1 09-29-2003 06:08 PM
Sealing head bolts pcesak Engine 10 05-13-2003 06:42 PM
Goop sealing interior welds? 327ImpalaSS Interior 3 02-15-2003 06:31 AM
