seam sealer - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-09-2009, 03:27 PM
seam sealer
at what point do you apply seam sealer
i am doing a transporter for cars at the min and replacing inner outer sills wings and arches that are all bare metal
i would have thought clean the metal then apply seam sealer then epoxy then repairs then 2k prime????
thanks
tommy
Old 07-09-2009, 04:23 PM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
I'm sure the Pro's will chime in here, but I Epoxy Primed, then used 3M two part Seam Sealer-hope this helps-
Old 07-09-2009, 06:38 PM
boatbob2
seam sealer......
Hi,i usually put the epoxy primer on with a small brush,trying to force the primer between the seam of the metal,,at least 2 coats,then i brush on the seam sealer, and smooth it with a squegee it works for me.
Old 07-11-2009, 11:58 AM
so if i epoxy all my van then seam seal and do my bondo repairs ?
What SEM seam sealer? glhx Body - Exterior 3 05-03-2009 07:37 PM
body filler vs. seam sealer daves66valiant Body - Exterior 1 04-16-2009 09:00 PM
Seam Sealer or ? jcclark Body - Exterior 4 05-06-2006 05:05 AM
Seam sealer staying tacky :( Ripped Body - Exterior 4 10-16-2005 12:36 AM
Body seam sealer cruzinTLT Body - Exterior 7 04-19-2005 09:24 AM
