Seam sealer? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-26-2009, 01:05 PM
Seam sealer?
Two questions guys first i have a 95 firebird and wondered how good the seam sealer is the factory used. I"m stripping my car down and you think I should leave their seam sealer on or put on my duramix? And second question is some spots that you can see should I strip the sealer off and put on some metal to metal evercoat filler on the seams or will the sealer be the best bet?
Old 09-30-2009, 11:37 PM
Rag top bird's Avatar
Hot rods are still the king
Im sure the OEM sealer is good stuff but it is going on 15 years now and I would strip it off and re apply 3M 3808 sealer and no on the second one
Old 10-01-2009, 07:47 AM
302 Z28's Avatar
Seam sealer is the ONLY thing you want to use, any other stuff like body filler will crack. 3M makes the best body seam sealer IMHO.
Vince
Old 10-01-2009, 09:20 AM
First off, DON'T EVER fill seams with anything but seam sealer or weld them up if you will, but NO polyester (metal to metal, reg "bondo", NOTHING) filler.
There is a certain amount of movement at those seams they need something that is a little flexable.
3808 3M couldn't be found in my latest 3M catalog and the number is so small I figure that is out of production.
If you want the best, you want a 2K sealer, Duramix, 3M, SEM, Evercoat, Fusor, I don't care the brand they will all be very similar.
Be sure you get a SEAM SEALER, and not a "Self leveling" seam sealer which flows way too much for 99% of seams.
Here is a "Basics" I did on seam sealers that may be of help. Click here
What SEM seam sealer? glhx Body - Exterior 3 05-03-2009 08:37 PM
body filler vs. seam sealer daves66valiant Body - Exterior 1 04-16-2009 10:00 PM
Seam Sealer or ? jcclark Body - Exterior 4 05-06-2006 06:05 AM
Seam sealer staying tacky :( Ripped Body - Exterior 4 10-16-2005 01:36 AM
Body seam sealer cruzinTLT Body - Exterior 7 04-19-2005 10:24 AM
