Seam sealer - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-17-2011, 07:25 PM
Seam sealer
I have replace a rocker panel and front fender on my truck and was wondering what does the factory use to seal the edges of the seam. Whats on there from factory looks like a caulk almost but is is harder and seems to last and I wanted to put it on where I spot welded the fender well to the fender to seal out moisture. Thanks
Old 04-23-2011, 04:38 PM
its probably just old dried out sealer all they use is seam sealer on it ive found out you can use body panel adhesive to and that stuff gets real hard supposedly you can do patch panels with it too but i prefer welding. oh yeah you can weld through it to so long as you get a good contact
Old 04-24-2011, 09:29 AM
put up or shut up
you can do patch panels with it but it shrinks and leaves a line. That stuff is better hidden under a flange. I did some bodywork on a charger that was getting lambo doors. I recall seeing metal placed behind the handle opening with adhesive and at a later point it was welded. Guy told me they put it in primer and it had ALREADY shrunk so they scrapped the idea and welded it in. If it shrunk before it even left the shop I don't even want to know what will happen in the summer. Then again, I'm not entirely sure it was panel adhesive but pretty sure it was.
Old 04-24-2011, 06:11 PM
I bought seam sealer at the body shop supply for 19.00 a tube
After reading the label it said it was polyurithane calk. I looked it up on the internet and read about PU calk. Went to Home depot and got some more for 6.00 a tube. Stickey stuff. Smooth it with your finger dipped in mineral sperits. It takes 48 hours to fully dry. Paintable when dry
seam sealer turbo t Body - Exterior 3 07-11-2009 11:58 AM
how much seam sealer to get..? PairOf69's Body - Exterior 1 08-30-2008 08:59 PM
Seam sealer. BIG DOG Body - Exterior 14 09-12-2007 08:34 PM
Epoxy sealer/seam sealer/paint equip Blackdog Body - Exterior 17 10-21-2004 11:19 PM
Seam Sealer nova33 Interior 3 04-20-2004 02:16 PM
