Is seam sealer on a firewall okay? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-01-2011, 06:59 PM
carnahan's Avatar
Can you put seam sealer on a firewall? I have a S-10 that I'm building and I have all the sheet metal welded in on the firewall, so now I need to do something with the seams. I bought a couple tubes of seam sealer and I was reading on the label, and it says to keep away from heat, sparks, open flames and MOTORS. It is Au-ve-co Products 1001 automotive body sealer. I asked a mechanic and he said it was okay, and the factory uses it. Just thought I would get another opinion. I would hate to get the motor back in and this stuff catch on fire. If not what kind of caulk is there that is high temp?
Old 01-02-2011, 05:23 AM
S10xGN's Avatar
Gotta love a turbo!
AFAIK, that warning is for application only where the product has not had a chance to cure and is still off-gassing volatile compounds...
Russ
Old 01-02-2011, 02:22 PM
superdirt's Avatar
3M makes a product we call 'drip check'. It's in a small tube just like the yellow gorilla snot/weather stripping glue. Its perfect for sheet metal seams and small cracks. We use it all the time and looks great when painted over also.
seam sealer kenn Body - Exterior 1 10-26-2009 09:49 AM
seam sealer turbo t Body - Exterior 3 07-11-2009 11:58 AM
Smoothing a firewall, seam sealer? johns2000 Body - Exterior 2 01-05-2009 02:33 PM
Seam Sealer or ? jcclark Body - Exterior 4 05-06-2006 05:05 AM
Epoxy sealer/seam sealer/paint equip Blackdog Body - Exterior 17 10-21-2004 11:19 PM
