seam sealer on hood skin - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-26-2012, 07:12 PM
Mach1460's Avatar
Last journal entry: Project 92' Eddie
Im analyzing my bronco for my upcoming paint job. Im going to paint the top of the hood (obviously) then wrap around where the skin goes over the "inner hood structure" (See the pic) i picked away at some seam sealer type stuff and i have some rust underneith which i want to wire wheel out of there and then primer and add some seam sealer type stuff back in there. Its very flat, im wondering how it can be re-applied this way, im thinking maybe pinch the end of the seam seal tube with a clamp or something similar???
It seems Ford must seam seal it then hit it with primer because under all the seam sealer is rust, and none anywhere else, maybe ill just skip the seam sealer and just get the rust out and epoxy as planned? does the seam seal hold any other purpouse?? Thanks
Old 06-29-2012, 12:57 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
It does just what the name implies. but it is used in some areas as a rattle deterrent!
the best place to put quarter skin seam Lizer Body - Exterior 93 08-02-2012 03:21 AM
how much seam sealer to get..? PairOf69's Body - Exterior 1 08-30-2008 08:59 PM
Quarter Panel Skin - Where to put seam cab Body - Exterior 2 03-11-2007 09:25 PM
How much Seam Sealer to use? satexasf150 Body - Exterior 3 10-26-2005 11:58 AM
Epoxy sealer/seam sealer/paint equip Blackdog Body - Exterior 17 10-21-2004 11:19 PM
