Seam Sealer When to Apply? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-20-2005, 06:19 AM
zonk's Avatar
Home Built Rods No Rules
Last journal entry: Home Made Sheetmetal bender plans
Need to use some seam sealer on my rain gutters and around my rear door on my delivery, should you apply this before or after I spray my fill primer or does it matter? Thanks
Old 02-20-2005, 04:36 PM
BarryK's Avatar
It really does not matter.
I do mine over epoxy.
It will work fine over a 2K primer but would not apply over a lacquer or acid etch.
To add to the above, the ideal way would be over epoxy for best long term results.
However both the single component and two component seam sealers will work great over bare metal.
Last edited by BarryK; 02-20-2005 at 05:47 PM. Reason: Off phone now and can think!
Old 02-21-2005, 02:29 PM
Put down a good bare metal primer before using any seam sealers. I've seen many failures when the technician applies the sealer over bare metal. If you read the instructions on almost all seamsealers it clearly states to be applied over a primer. I will not apply any seam sealer over bare metal reguardless if it's a laquer base, urethane, or two component product. Look at most of the cars produced in the 60's and 70's and you'll see failures in the sealer areas where the sealer has cracked and corrosion starts because there is nothing under the sealer to protect the bare steel- Mopars were the worst from what I've seen. JMO Bob
Old 02-21-2005, 03:20 PM
zonk's Avatar
I have a good etching primer down now ,some reason I was questioning myself if a good fill primer would stick to seam sealer, thanks for the clearification
Bare Metal Mollard Body - Exterior 71 09-25-2008 01:48 PM
"Basic of Basics" What are the new paints all about? Centerline Body - Exterior 0 07-26-2004 06:43 AM
Lacquer primer question badriand Body - Exterior 18 07-23-2004 03:08 PM
Seam Sealer nova33 Interior 3 04-20-2004 02:16 PM
Should I Apply Sealer Before Painting??? STATUTORY GRAPE Body - Exterior 3 09-15-2003 07:27 AM
