In search of undrillled dropped tube axle - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-30-2005, 06:11 PM
Looking for a dropped tube axle for my early Chevy rod project, however all the ones I find in the larger catalogs and parts houses are pre-drilled for a 4-bar/radius rod batwing setup.
Since I'll be u-bolting this axle to the front parallel leaf springs on my early Bowtie, I don't need the extra holes. All I need is the dropped tube (4"), with kingpin / spindle mounts on each end.
Anyone have a link or number where I can pick one up?
Thanks,
Kurt
'28 Chevy Rod (in the planning stages)
Old 06-30-2005, 06:34 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Axle
Speedway part# 913-35111 has welded on brackets that could be cut off and replaced with the spring pads for your app..and it is a 4" drop..
that axle uses 49-54 chev spindles..might be worth a try..
OMT
Old 06-30-2005, 06:48 PM
That'll do
Wow, missed that one at Speedway. I have their catalog on Cd and it can be hard to navigate at times.
Still hard to believe that there isn't someplace / some guy out there making just plain ol' dropped tubes for us Chevy and Mopar (front leaf spring) rod builders.
Thanks for the heads up!
Kurt
Axle Tube Number ID Help Morex52 Transmission - Rearend 2 01-08-2005 08:00 PM
dropped axle on 64ss chevelle hot64ss Introduce Yourself 1 12-05-2004 09:01 PM
Dropped Axle adtkart General Rodding Tech 5 12-27-2003 07:45 PM
determining right dropped axle adtkart Suspension - Brakes - Steering 4 08-12-2003 05:48 PM
'37 Ford tube axle on eBay..... SJFast Suspension - Brakes - Steering 0 10-09-2002 09:19 AM
