LinkBack | Thread Tools |
[ Searching for affordable machine shope to machine a Merlin aluminum bare block ]
Hello, I have made a killer deal for a World Product Merlin X 10.200" tall deck bare block.
That is a raw casted block that will need to be done all of the screw threads and machining like the Main Caps Head bolt bores Tranny flange (how it looks) Water pump screw threads must get sleeved square decked align honed freeze pluged torque plate bored and mole honed need the bearings and what ever else. Who know a good, cheap, and competent on such work, machine shop who can do that? The seller have to measure it out before but he is almost sure that the raw bore is 4.49". What displacement do you recommend for a 68 Impala with 4l80E and 12 bolt posi? My friend said: Man, what a quesiton - the biggest possible (should be 632cid on that block ), but I dont know, what is your opinion members? The price of a 540cid, 598cid, 604cid or 634cid is nearly the same so with which one to get along is my confusion. If there is any machine shop in the forum, I need the FAIR offers right now for machining and a rotating assembly matching that block. So if you want the order come in touch by bow-tie@gmx.at right now. Hannes
I think I'd walk away from that deal. If that is a good rough core, which is a gamble, you are looking at a ton of money to get that block ready for prime time. Maybe Carl could give you a rough idea what it would take to get that block in shape but I suspect you won't be saving much, if any, money in the end.
You are looking at a ton of machining and setup time. It won't be cheap. |
I would not even venture a guess. There is no way to even tell if that casting has even been heat treated yet. Doesn't look like it.
