Searching for crate rebuilt 700R4... - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2007, 05:32 PM
Awhile back, I posted that the Internal Reaction (Ring) Gear shattered in my 1982 GMC 2500 4x4 truck. Here are the links to my previous posts.
http://67-72chevytrucks.com/vboard/s...d.php?t=217634
Internal Reaction (Ring) Gear shattered in 700R4...
I am only aware of these companies. I need more ideas...
Sold thru Advance Auto, Accurate Transmissions
They have an 18 month, unlimited mileage warranty.
http://www.accuratetrans.com/
Sold thru Jegs and Summit, TCI Auto
Warranty info unknown at this time.
http://www.tciauto.com/
Bow Tie Overdrives in Hesperia, CA. They have a 12 month, unlimited mileage warranty.
http://www.bowtieoverdrives.com
Old 02-01-2007, 08:44 AM
jleeheat's Avatar
I've bought a TCI 4L80E and had good results fwiw.
My family owns a trans. shop in Lawton Oklahoma but shipping may be non-cost effective. The trans. I bought came from TCI because 4L80E's are scarce and the family shop did not have one. Let me know if you want a price for trans. or call them yourself. Allied Trans. @ 580-357-1100. Let them know Jim sent you.
It might be more cost effective to buy a later model salvage yard trans. with factory updates and use that as an overhaul candidate. If they'll let you pull the pan and inspect for material in pan before purchase, that will give you a very good idea as to it's condition assuming no one has had the pan off and cleaned it already. You may be able to install it without anything more than a front seal replacement if it's a good unit. Some salvage yards test trans. before removal and sell trans. with a guarantee that it will work properly to start with. For how much longer than that I guess is dependent on the salvage yard itself.
Good luck,
Jim
Putting a 1987 700R4 in my 1982 GMC 4x4... indy_85stariones Transmission - Rearend 12 04-28-2007 02:04 PM
Rebuilt 700r4 - no reverse Anton Transmission - Rearend 5 06-10-2005 10:55 PM
Rebuilt 700r4 Burnt in 10 miles subman17 Transmission - Rearend 9 02-15-2004 03:41 PM
Need advice: 700R4 banging in 1st 360Camaro Transmission - Rearend 11 11-20-2003 06:44 PM
What do pro trans builders do with rebuilt 700R4 planetary bearings? Jason Transmission - Rearend 18 09-09-2003 03:55 PM
