Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - searching for an idle problem fix
Old 01-20-2013, 08:43 AM
jdaviscgaz's Avatar
jdaviscgaz jdaviscgaz is offline
I got it thanks to you guys
Pulled the carb apart and noticed that the accel pump was sitting pretty far down in the cylinder so removed that one and placed a shorter one from another Quadra jet honed the cylinder with dremal sanding tube (just enough to scuff the edges to break the glaze)replaced check ball. Started it up and it wouldn't fire. After some cursing and tears haha just kidding on tears. Found I was out of gas. Put a couple of gallons in it and varoom she's alive and singing. Grab a turkey and set it over the back wheels were gunna smoke it. Thank you guys for the help your awesome. One ? Off subject why did this post move? Couldn't find a carb specific site. Just not sure where I screwed up for future use.
