Searching for a rear end. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-22-2006, 05:55 PM
Gr8 '48 bow tie's Avatar
Be American, Buy American!
Help, I can't find my rear end. I've walked miles and miles in the salvage yard looking, so now I need your help.
My '48 Chevy is 47 3/8" outside to outside frame rails. I have information that tells me that a 54" - 55" rear end will fit. A "68 - 72 Chevelle or a '67 full size Chevy should fit.
Next questions are, What if any lug bolt patterns are the same as Chevy? and when was the last leaf spring end used? All I seem to find is coil springs in the rear, so I need to know what process I need to follow to convert to coils?
Thanks
Old 05-22-2006, 06:03 PM
Wiki Edits: 31
why convert to coils when all u have to do is cut off all the coil bracketry and run ubolts with the leafs. I'v heard that Camero rear ends are bolt in. any rear end with a 5X4.75" bolt pattern will be the same as yours.
Old 05-22-2006, 06:28 PM
Click here for a fairly good list of rear ends ...
http://www.quickperformance.com/Tech...us_measure.htm
They measure rear ends this way ... it takes in the total width ... backing plates and brake drums vary ... so measure overall width ... to be safe ..
I suggest a 68 to 74 Nova ... or a 2 wheel drive S-10 ...
Old 05-30-2006, 10:44 AM
74 - 78 Nova or Skylarks work well. I picked one up at the local scrap yard for $75. It was a dogleg but the price and availability were right at the time. There should be plenty of them just about anywhere.
Barry
Thump Thump in rear end?? HotRodMan Suspension - Brakes - Steering 7 01-24-2007 06:09 PM
1975 8.5 rear end camino_man Transmission - Rearend 6 09-18-2004 05:32 AM
Rear End Change black66 Transmission - Rearend 4 01-28-2004 09:21 AM
Important rear end mounting question 71gtx Transmission - Rearend 2 01-04-2004 06:05 PM
Ford 7.5" Rear End Traction-Loc Install nightrain_rod Transmission - Rearend 2 12-30-2003 06:38 PM
